Pintura
Coordinating a PoE 2 Frontier Push With U4GM 19 horas 10 minutos antes #39906
  • Glico
  • Avatar de Glico Autor del tema
A castle capture in PoE 2 can leave you with more territory to defend and little room to advance. In the Conquerors of Wraeclast preview, neighboring ownership matters because hostile castles can pressure each other through mutual sieges. Planning upgrades with Path of Exile 2 Currency addresses character strength, while choosing a useful target requires reading the territorial map. Before committing to another fortress, check what its capture would connect, expose, or place under pressure.
Choose a target that improves your border
The preview describes adjacent castles from rival factions gradually wearing down each other's defenders. That makes the surrounding territory part of the target assessment. A fortress already facing friendly holdings presents a different opportunity from an isolated position deep inside hostile territory.
When several targets look accessible, compare their positions before choosing the most convenient fight.
Look for a castle that connects separated friendly holdings.
Check how many hostile neighbors would border the captured position.
Consider whether a neighboring capture could put your intended target under siege pressure.
A narrow advance can create several exposed holdings without establishing a useful cluster. Capturing nearby positions may give your faction a more coherent area to support, but the preview provides no fixed capture count that guarantees a surround. Treat the map as a changing set of relationships rather than a sequence of boxes to clear.
Coordinate around one contested area
Faction members attacking unrelated castles may each make progress while leaving a promising offensive unfinished. A shared target area gives individual captures a clearer purpose: connecting territory, supporting an exposed position, or extending pressure along an existing frontier.
Keep the objective specific enough that other players can recognize useful follow-up targets. "Connect these holdings" offers a clearer direction than simply asking for more castles. Once ownership changes, reassess the nearby options instead of continuing along a route chosen under different conditions.
The described catch-up system also changes how castle totals should be interpreted. Expansion becomes easier for the faction with the fewest castles and harder as ownership grows. A large territory therefore still needs attention at its borders, while a smaller faction has reason to pursue recoverable positions.
Commit siege resources where timing matters
Rare faction items introduce another allocation decision. Preview details describe effects such as Blood Moon that accelerate a siege, but they do not establish precise efficiency values. The useful question is whether an earlier capture would change your faction's immediate options.
Read the item description before committing a rare siege resource.
Prioritize a contested target when its capture supports a coordinated offensive.
Keep resources available when the surrounding territory offers no clear follow-up.
Spending an item on an isolated victory may produce little territorial value. Using it during an organized push could be more useful, provided nearby players can act on the opening. Exact siege timings remain unspecified, so avoid planning around an assumed completion window.
Match commander duties to territorial pressure
Commanders can run Maps or defend castles, creating a choice between personal progression and territorial support. A sheltered holding gives you a different reason to assign a defender than a threatened castle connecting friendly positions. Review those assignments when the border changes.
Access arrives in stages. The preview places the first commander after your first faction castle in the league storyline, with the remaining two following the league's Pinnacle Boss. Plan around the commanders you have available rather than assuming every defensive option opens immediately.
Before your next session, choose one territorial objective and check whether your character, commanders, and faction support are ready for it. If you are considering POE 2 Orbs for sale for equipment upgrades, identify the specific combat limitation first. Stronger gear can support an attempt, but the castle still needs to justify the resources and attention its position demands.
